I have a similar configuration that work on one machine but don’t on others…
I have an application Ignition that stores historian on an SQL server database.
While on my own machine it works, on my collegues machines it doesn’t.
In the data tables they get only a few lines per tags with dataintegrity value at 300, 600 or 500.
A few lines means : two lines per tag each time Iginition is restarted.
Our tags are defined using the same XML file, so the configuration is very similar.
What can cause this problem ?
