Hello, I’m following the instructions at https://docs.inductiveautomation.com:8443/display/SE/Debugging+in+IntelliJ to try to launch the Designer in the debugger. I receive the following errors after supplying a username and password:
18:54:19.654 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.reporting.designer.ReportingDesignerHook" not found for module "Reporting".
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadModules(IgnitionDesigner.java:649)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startup(IgnitionDesigner.java:369)
at com.inductiveautomation.ignition.designer.DesignerStartupHook$2.run(DesignerStartupHook.java:346)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.reporting.designer.ReportingDesignerHook
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadModules(IgnitionDesigner.java:646)
... 16 common frames omitted
18:54:19.712 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.sfc.designer.SFCDesignerHook" not found for module "SFC".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.sfc.designer.SFCDesignerHook
18:54:19.718 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.xopc.DesignerModuleHook" not found for module "OPC-UA".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.xopc.DesignerModuleHook
18:54:19.722 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.ignition.modules.serial.SerialSupportDesignerHook" not found for module "Serial Support Client".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.ignition.modules.serial.SerialSupportDesignerHook
18:54:19.746 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.factorysql.designer.FSQLDesignerModuleHook" not found for module "SQL Bridge".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.factorysql.designer.FSQLDesignerModuleHook
18:54:19.750 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.opccom.DesignerModuleHook" not found for module "OpcCom".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.opccom.DesignerModuleHook
18:54:19.754 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.secsgem.DesignerHook" not found for module "SECS/GEM".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.secsgem.DesignerHook
18:54:19.758 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.ignition.alarming.designer.DesignerHook" not found for module "Alarm Notification".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.ignition.alarming.designer.DesignerHook
18:54:19.761 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.mobile.designer.MobileDesignerHook" not found for module "Mobile".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.mobile.designer.MobileDesignerHook
18:54:19.765 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.eam.EAMDesignerModuleHook" not found for module "Enterprise Administration".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.eam.EAMDesignerModuleHook
18:54:19.767 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.xopc.drivers.dnp3.designer.ModuleHook" not found for module "DNP3 Driver".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.xopc.drivers.dnp3.designer.ModuleHook
18:54:19.770 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.designer.IgnitionDesigner - null
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Hook class "com.inductiveautomation.symfact.designer.SymbolFactoryDesignerHook" not found for module "Symbol Factory".
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.symfact.designer.SymbolFactoryDesignerHook
I do not have any errors if I launch the designer via a JNLP link downloaded from the Gateway configuration UI.
