Errors when compiling Project
I set up a development server following the example in the SDK. I'm having an issue when I compile - it looks like it's trying to download packages from inductive but I get a not authorized error. I'm sure I followed all the steps correctly. Is there some kind of certificate I need to install?
No, there shouldn't be.
How about you share something more useful like error messages?
Certainly. This is what I get (Windows 10):
Starting a Gradle Daemon (subsequent builds will be faster)
Required keystore file location not found. Specify via flag '--keystoreFile=', or in gradle.properties file as 'ignition.signing.keystoreFile='
Required certificate file location not found. Specify via flag '--certFile=', or in gradle.properties file as 'ignition.signing.certFile='
Task :designer:compileJava FAILED
FAILURE: Build failed with an exception.
  • What went wrong:
    Execution failed for task ':designer:compileJava'.
Could not resolve all files for configuration ':designer:compileClasspath'.
Could not resolve com.jidesoft:jide-action:3.7.4.
Required by:
project :designer > com.inductiveautomation.ignitionsdk:designer-api:8.1.20 > com.inductiveautomation.ignition:designer:8.1.20
Could not get resource 'https://nexus.inductiveautomation.com/repository/public/com/jidesoft/jide-action/3.7.4/jide-action-3.7.4.pom'.
Could not GET 'https://nexus.inductiveautomation.com/repository/public/com/jidesoft/jide-action/3.7.4/jide-action-3.7.4.pom'.
No PSK available. Unable to resume.
Could not resolve com.jidesoft:jide-dialogs:3.7.4.
Required by:
Could not get resource 'https://nexus.inductiveautomation.com/repository/public/com/jidesoft/jide-dialogs/3.7.4/jide-dialogs-3.7.4.pom'.
Could not GET 'https://nexus.inductiveautomation.com/repository/public/com/jidesoft/jide-dialogs/3.7.4/jide-dialogs-3.7.4.pom'.
peer not authenticated
Sounds like something on your network is unhappy with our host, as @raman_saini suggested. You can literally click that link in a web browser and you should get an XML document.
