Any estimate on when licensing will be enabled? Sepasoft has a couple of major features that depend on how multiple gateways are licensed (Enterprise and Task Routing). The reason I ask is to judge if we should make a custom build for testing that assumes that Sepasoft modules are licensed. If its only a few weeks away, then we may be able to wait. Thanks for any info you can provide.
Hi Jeff. We don't really have a good estimate for when 8.3 licensing will be enabled. I would say that it would probably be best to move forward with the custom build for your testing, but I'll continue to try and chase down an answer for when the licensing could be available.
Thanks Andrew. That helps a lot. Don't move anything around for us. The custom build I talked about is going to be fine for a while.
