I'm using @pturmel 's Ethernet/IP v2 module to make a host simulation device from a L5X file.
In the PLC I have a tag UDT that has another UDT inside. The path to the tag in the PLC is Bin_1.Level.Input.
However, I'm not seeing that in the tag browser after adding the L5X. The OPC addresses that I'm seeing use an underscore instead of a period for anything that's not the root-level UDT (the last period).
So, instead of the expected Bin_1.Level.Input I have Bin_1_Level.Input.
Is this the expected behavior? Is this behavior different from the AB Logix Driver?
