ETHERNET/IP Sensor Integration Gateway - SIG200
This SIG200 is an ethernet/IP sensor gateway. Can i connect this device directly with Ethernet/IP protocol?
Thanks a lot
Rodrigo
Probably with @pturmel 's ENIP module, but not with anything first party Ignition driver.
Yes, seems to use a generic profile. There would need to be some code on the Ignition side to manage the I/O Link traffic within the connection.
Thanks a lot for the answers, This module works with ignition edge 7.9?
No, Edge in general does not allow third party modules to be installed.
