EV charger OCPP1.6 protocol choice of integration with ignition
Hi!
I'm trying to implement a HMI for an EV charger. The protocol of communication used by the charger is OCPP1.6 :
The OCPP1.6 protocol of the charger is based on JSON over WebSocket. Currently I'm able to communicate between ignition and the charger with a hardware gateway modbus to OCPP1.6:
https://www.intesis.com/fr/produits/protocol-translators/modbus-gateways/ocpp-to-modbus-tcp-rtu-gateway
But I found some python drivers parsing OCPP1.6 transactions that makes me wonder the necessity of the hardware gateway to communicate with ignition:
https://ocpp.readthedocs.io/en/latest/central_system.html
So, do you have any suggestions on how I could communicate with an EV charger directly with ignition over websockets without the need of the physical gateway modbus? A solution that I see is to create a python software modbus OCPP1.6 gateway running outside of the ignition project, but is there any more straight forward solution?
Thank you!
Sounds like an opportunity to make a new driver module with the SDK. (:
Might be doable in jython with jetty's websocket support.
Hello Emile, I would realy be interested to communication with you and know how does the Intesis work.
I could also show you what I have done with Ignition. (CSMS solution)
I'm going to reactivate this thread because I have found myself int he same situation. Has anyone else been able to get Ignition to connect to OCPP v1.6 or 2.0 chargers?
for your information there is a new OCPP driver for Ignition made by Baudrate IO
Open Charge Point Protocol for Ignition SCADA (baudrate.io)
