Yes I’m sure. And it actually works perfectly on the internal frame being close it closes both windows. It only does not work on the VisionWindowsClosed. I’m now sure why . But I tried the same two line script and it works actually also on frameOpened. Closing , close , but not windows closed. Did you tried and it worked ? If you let me know. Thank you for the help
