–Ignition 7.5.3 (b1163)/Win2k8 Server Enterprise on VMWare ESXi 5.0–
I know I must be missing something absurdly simple and would greatly appreciate any help from the forum!
I set up the following event script (gateway) to fire on appropriate tag changes:
import string
from app import CIP_Log #<-- also tried "import CIP_Log" and "import app"
strWho = event.tagPath.itemName
if string.find(strWho, "CIP2") >= 0: CIP_Start("CIP2")
elif string.find(strWho, "CIP3") >= 0: CIP_Start("CIP3")
elif string.find(strWho, "CIP4") >= 0: CIP_Start("CIP4")
elif string.find(strWho, "CIP5") >= 0: CIP_Start("CIP5")
elif string.find(strWho, "CIP6") >= 0: CIP_Start("CIP6")
elif string.find(strWho, "LACTA") >= 0: CIP_Start("LACTA")
which generates the following error:
File "<TagChangeScript:UD_Datalogs/All_CIP_Start>", line 8, in <module>
NameError: name 'CIP_Start' is not defined
at org.python.core.PyException.fillInStackTrace(PyException.java:70)
at java.lang.Throwable.<init>(Throwable.java:181)
at java.lang.Exception.<init>(Unknown Source)
at java.lang.RuntimeException.<init>(Unknown Source)
at org.python.core.PyException.<init>(PyException.java:46)
at org.python.core.PyException.<init>(PyException.java:43)
at org.python.core.PyException.<init>(PyException.java:61)
at org.python.core.Py.NameError(Py.java:246)
at org.python.core.PyFrame.getname(PyFrame.java:257)
at org.python.pycode._pyx43.f$0(<TagChangeScript:UD_Datalogs/All_CIP_Start>:13)
at org.python.pycode._pyx43.call_function(<TagChangeScript:UD_Datalogs/All_CIP_Start>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1261)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:539)
at com.inductiveautomation.ignition.common.script.TagChangeScriptManager$TagChangeScriptHandler$Runner.run(TagChangeScriptManager.java:219)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
In the Script Module Editor, I have one package, the default “app”, containing two scripts “CIP_Log” and “Lookups”. The first few lines of CIP_Log are:
def CIP_Start(strCIP_Unit):
import system
import datetime
import app.Lookups
# --more code below--
… what am I missing? It shouldn’t be a scope issue…
