LstRdBxTxt is a text field on “Main Window” root container on this project.
I try to run it and immediately get an error “NameError: name ‘event’ is not defined”
yet I see lots of examples showing this syntax, so I think I am missing an import or something.
put that script on a action performed on a button component on the same window as your text component and it will work… I dont believe you can use it in the script tester like you are trying to do.
