Event Streams status and config change events
I am having a few issues with threads becoming orphaned when I change config on the Designer screens. I am not seeing where the change in config will send an event to the module to reinitialise the module with the updated config. Does the Event Stream Source re-run the onStartup() function every time the config changes or is that up to us to detect and implement?
public class TcpSource implements EventStreamSource {
You should get onStartup() and onShutdown() called on the EventStream, and create() called on your Factory, as necessary.
I think I found my issues, the onStartup() was hanging due to a loop and not quite finishing, which made Ignition never register the module had started correctly. I think this was delaying or preventing other changes.
