Eventflags in alarm journal
Hello,
I have Ignition ver. 8.1.13 where I use microsoft sql server and a PLC that comunicate by OPC-UA with Ignition.
I do not understand why, during startup, Ignition save the alarm journal with eventflags nr.28.
I know meaning of this Alarm Journal - Ignition User Manual 8.1 - Ignition Documentation
but I do not understand why Ignition save that event during startup.
Is possible set Ignition that not save this?
Why Ignition do save this eventflags during startup?
Why does it bother you ?
Are you using this flag for something and that value messes with your logic ? If that’s the case, I suggest you fix the logic to fit the data, and not the other way around.
Because I have inside the DB more rows with this similar record and after I must create one more filter in the visual table.
I want understand why happens this situation not to record more rows nonsense.
Did you have any luck finding out?
No, I do not find the solution until now. Do you have some advice?
