Would anyone have an example of how the Serial Gateway module can be used to allow clients to write to the serial port of the gateway? I have searched within forum, on the site and thru the manuals but haven’t had much luck.
I’ve used the serial client module before and that works the way I have been using it with the serial ports directly on the clients. However, for this I can only use the serial port on the gateway, so I have the gateway module but I’m trying to figure out how to have the clients read and write to the port on the gateway.
Such as my scripts are client scoped and I’m trying to figure out how to scope the script to run on gateway.
I need the clients to be able to read the raw characters streaming from the gateway serial port and the clients be able to write to the same serial port on the gateway.
