The dynamic property for this label tries to run an app and I get a null exception error but I cannot figure out what is wrong. If there is a better way for the label to show when I have an alarm active I am game to try something else.
APP defined as:
def activeAlerts():
import system
return system.alert.queryAlertStatus(activeAndUnacked=1).rowCount
Error as follows:
Exception: Error executing expression binding on
Temporary.Root Container.AlarmLabel.NumAlarms
caused by ExpressionException: Error executing script for runScript() expression:app.alert.activeAlerts()
caused by Traceback (innermost last):
File “expression:runScript”, line 1, in ?
File “module:alert”, line 3, in activeAlerts
java.lang.NullPointerException
I think the system.alert.queryAlertStatus(activeAndUnacked=1) is returning null. You may want to do the following for you activeAlerts function:def activeAlerts():
import system
ds = system.alert.queryAlertStatus(activeAndUnacked=1)
if ds == None:
return 0
else:
return ds.rowCountTry that out and let us know.
Sadly the same result. Would you rather have the error copy?
java.lang.NullPointerException: java.lang.NullPointerException
Ignition v7.1.6 (b5739)
Java: Sun Microsystems Inc. 1.6.0_22
Well it must be getting an error in our function. I will check it out. In the meantime you can wrap all of the code in your function into a try…except block like the following:def activeAlerts():
import system
try:
except:
return 0
def activeAlerts():
import system
java.lang.Exception: Error executing expression binding on
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:56)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.childInteractionUpdated(ExpressionPropertyAdapter.java:31)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction.actionPerformed(AbstractPollingFunction.java:80)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
Caused by: com.inductiveautomation.ignition.common.expressions.ExpressionException: Error executing script for runScript() expression:app.alert.activeAlerts()
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:57)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:50)
… 12 more
Caused by: Traceback (innermost last):
File “module:alert”, line 13, in activeAlerts
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlertUtilities.toDataset(AbstractAlertUtilities.java:106)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlertUtilities.queryAlertStatus(AbstractAlertUtilities.java:40)
at sun.reflect.GeneratedMethodAccessor67.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:310)
at org.python.pycode._pyx4.activeAlerts$1(<module:alert>:13)
at org.python.pycode._pyx4.call_function(<module:alert>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyFunction.__call__(PyFunction.java)
at org.python.core.PyObject.invoke(PyObject.java)
at org.python.pycode._pyx1.f$0(<expression:runScript>:1)
at org.python.pycode._pyx1.call_function(<expression:runScript>)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:391)
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:54)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:394)
... 14 more
at org.python.core.Py.JavaError(Py.java)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlertUtilities.queryAlertStatus(AbstractAlertUtilities.java:42)
... 15 more
It looks like this is a bug that we have fixed in version 7.1.7. This issue is caused by calling system.alert.acknowledgeAlert() with empty string parameters. Once you do that, a null state gets introduced into memory and you start getting this error.
To fix this: stop the Ignition service, remove the .alerts file (C:\Program Files\Inductive Automation\Ignition\contexts\main.alerts), and then restart the service.
