chi
March 28, 2013, 2:30pm
1
There seems to be a little bug that causes an exception in the Designer if the the SQL Bridge module is restarted while a designer is connected.
Version is 7.5.6.
After the module restart, selecting a transaction group in the designer throws the follwing exception:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.factorysql.clientcomm.SessionGroupStatisticsListener cannot be cast to com.inductiveautomation.factorysql.clientcomm.SessionGroupStatisticsListener
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:244)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:751)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:54)
at com.sun.proxy.$Proxy14.setStatsMonitoredGroups(Unknown Source)
at com.inductiveautomation.factorysql.designer.FSQLDesignerModuleHook.setCurrentMonitoredGroupId(FSQLDesignerModuleHook.java:420)
at com.inductiveautomation.factorysql.designer.FSQLDesignerModuleHook.setSelectedResources(FSQLDesignerModuleHook.java:672)
at com.inductiveautomation.factorysql.designer.model.navtree.FSQLRootTreeNode.onChildrenSelected(FSQLRootTreeNode.java:129)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.dispatchSelectionEvent(AbstractNavTreeNode.java:624)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.dispatchSelectionEvent(AbstractNavTreeNode.java:620)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$SelectionListener.valueChanged(NavTreePanel.java:437)
at javax.swing.JTree.fireValueChanged(Unknown Source)
at javax.swing.JTree$TreeSelectionRedirector.valueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPath(Unknown Source)
at javax.swing.JTree.setSelectionPath(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.selectPathForEvent(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressedDND(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(Unknown Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at com.jidesoft.docking.b.a(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.handleEvent(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager$49.eventDispatched(Unknown Source)
at java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Unknown Source)
at java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Unknown Source)
at java.awt.Toolkit.notifyAWTEventListeners(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.ClassCastException: com.inductiveautomation.factorysql.clientcomm.SessionGroupStatisticsListener cannot be cast to com.inductiveautomation.factorysql.clientcomm.SessionGroupStatisticsListener
at com.inductiveautomation.factorysql.FSQLProjectRunner$FSQLRpcHandler.setStatsMonitoredGroups(FSQLProjectRunner.java:602)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:123)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:398)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(null)
Ignition v7.5.6 (b1316)
Java: Oracle Corporation 1.7.0_17
Yes, after the restart, an object that is held in the designer session is no longer valid. Restarting the designer should fix the problem, or you might need to terminate the session from the gateway status page. We’ll fix it soon, though.
Regards,
