Getting an error message stating “exception occurred during async write operation”
Has anyone received this error or understand what is trying to speak to?
The detailed error message reads:
CompletionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
Caused by: java.net.SocketTimeoutException: Read timed out
The error message you’ve posted is just indicating the gateway didn’t return a response in time. Check the gateway’s log for an error message happening at the same time.
I’ve watched the log in the gateway and I don’t see an error happening at the same time. This problem started to occur when I changed my scripting of buttons writing to tags. I had previously had my Control Value of the button write to exampletag.value - This had been creating another error previously saying “error writing to tag.” I saw on another forum that by taking out the “.value” at the end of what tag I was writing to, could get rid of that error. Once I took away the “.value” I got rid of that error message, but that’s when I got this new error of “async write operation.” I’m seeing the machine I’m working on see the effects of this new error. I try to make some things move by pressing some buttons and nothing happens, but a minute later, that error message will pop up and then everything on the machine tries to move at the same time. I hope this helps describe what I’m experiencing.
Can you post your script? And the full ‘details’ of the error message?
What you’re describing sounds like a scripting action locking up the ‘Event Dispatch Thread’. Java Swing (the technology behind the Designer and Vision clients) is a single-threaded GUI - so anything that takes a large amount of time to run (ie, a blocking write to tag, if you’re running your script on the EDT) will prevent anything else on the GUI from running in that time - including the act of repainting the GUI to move your components around, your mouse cursor, etc, etc.
There are a variety of ways to fix or mitigate that problem, but it’s hard to advise what’s best without seeing exactly what’s causing the problem.
