Exception while starting up module Report-component example
Hi everyone, i have a problem when i install a module example (Report-component) in “example SDK ignition”. Gateway Ignition catch exception with log “Exception while starting up module com.inductiveautomation.ignition.examples.report-component” when i import .modl file had been built by maven 3.2.
Can you solve this problem, please!
Thank you!
restart the module and look at the logs.
java.lang.Exception: Exception while starting up module “com.inductiveautomation.ignition.examples.report-component”.
Caused by: java.lang.NoClassDefFoundError: com/inductiveautomation/rm/shape/j2dshapes/AbstractJ2DShape
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(Unknown Source)
at java.base/java.security.SecureClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader$1.run(Unknown Source)
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:37)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.loadClass(ModuleClassLoader.java:85)
at com.inductiveautomation.ignition.examples.report.component.gateway.GatewayHook.startup(GatewayHook.java:23)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2434)
… 12 more
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.rm.shape.j2dshapes.AbstractJ2DShape
… 26 more
8.1.10 (b2021090812)
Azul Systems, Inc. 11.0.11
I restarted module but not resolve this. Should this problem come from Ignition version?
This doesnt look like a problem with ignition but with the build you made. It didnt include the class, did you do a correct import?
oh, I don’t know, but I think this is successful build and correct imported.
Check if this class is in the module file.
And if you have this turned on
altho i would think the ignition gateway should have acces to those files anyways, weird
Thank you so much.
I solved this problem when I change scope from ‘provide’ to ‘compile’.
You shouldn’t use “compile” for this dependency.
It looks to me like the real problem is the reporting component example is still using the old module ID of the reporting module instead of the new one: com.inductiveautomation.reporting
If you change rept to com.inductiveautomation.reporting in these dependencies it should work…
Thanks for your support!
