Exchange error when trying to import
Hello. I’ve tried (not all at once) importing all of the Exchange .zip files marked Beginner and get an error every time I try. You can see this error, I’ve attached a screen shot.
Is there something I’m doing wrong?
tia,
Eileen
Which exchange package is it? If you manually unzip the file, are there any resources in it?
Thanks! I was able to get them (.zip files) to load when I Imported them from the Project from the Designer Launcher.
It wasn’t working for me when I tried importing from the Gateway.
Hi, could you please explain more regarding the problem, i’m facing the same issue… i cant get it to work…
