Hi everyone,
I am trying to generated a report based on the status of a tank, the tank is defined by a UDT which contains a tag ‘Status’. When the value of this tag is ‘1’ = Running and ‘0’ = ‘Not running’.
Whenever the tank finished with the batch run, the status of the variable ‘status’ goes automatically back to zero.
I have created a script that whenever the operator clicks on a button ‘Start’, this captures two parameters for my report in a memory tag ‘StartDate’ and ‘user’ and saves then in a memory tag.
The challenge I am facing is to call, system.report.executeAndDistribute whenever the value of tag ‘status’ of a given tank changed from 1= Running to 0= Not running.
What I have in mind is something like this:
Under Schedule in reports – Select Custom, and in Actions create a script as follows:
#Declare variables and paths
#Tankname = How can I make this variable dynamic?
#Operators select from a dropdown menu the tankname and a template displays the right info for the selected tank.
#I would like that the trigger action runs for any given tank.
pathEndDate = "[default]Production/" + Tankname + "/Report/EndDate"
pathStartDate = "[default]Production/" + Tankname + "/Report/StartDate"
pathTanknumber = "[default]Production/" + Tankname + "/Report/Tanknumber"
pathTanktype = "[default]Production/" + Tankname + "/Report/Tanktype"
pathuser = "[default]Production/" + Tankname + "/Report/user"
pathstatus = "[default]Production/" + Tankname + "/Status"
EndDate = system.date.now()
StartDate = system.tag.readBlocking(pathStartDate)
Tanknummer = system.tag.readBlocking(pathTanknummer)
Tanktype = system.tag.readBlocking(pathTanktype)
user = system.tag.readBlocking(pathuser)
status = system.tag.readBlocking(pathstatus)
#Variables for the report (Parameters)
reportParameters = {"StartDate":StartDate, "EndDate":EndDate, "Tanknumber": Tanknumber, "Tanktype": Tanktype, "user": user}
settings ={"path":"C:\\Ignition Reports", "fileName":"Report.pdf", "format":"pdf"}
#Here I would need to write a condition to check if the value of ‘status’ was already 1 and changed to zero. If this is true:
system.report.executeAndDistribute(path="My Report Path", project="My Project", parameters=reportParameters, action="save", actionSettings=settings)
If the condition is false it should loop until this becomes true. Any idea on how to set this condition?
The condition needs to be evaluated for every tank (we have 5 identical tanks working with UDTs).
Alternatively, I was thinking that perhaps I can add 5 different schedules, set them all to custom, and pass a tankname parameter to them. So that the script knows into which UDT to look for the values, and in the actions set a script with the condition that I still need to figure out how to define.
Would anyone be so kind to point me into the right direction?
Thanks in advance,
David
