Hello all,
Trying to execute a bunch of reports filtered by a row selector and save them all to a given folder. That wasn’t the problem, it’s been working for a few hours until it stopped working. I’ve been investigating and found out that executeReport doesn’t return anything, just getting an empty byte array.
Running this from a simple button click in my project gives the same empty byte array
bytes = system.report.executeReport("loadtest/standard", "testcenter", { 'certificate id':'18d7dd29-1586-11ec-b712-4c028912125d'}, 'pdf')
print len(bytes)
Showing the same certificate in the Report Viewer component works fine and I can right click and save to pdf with no problem. I know it’s not a problem with the path or project arguments as they’re raising an error if invalid.
I hope someone can help figure out what’s going on
