Hey all,
I’m using an RFID reader made by Impinj to constantly read RFIDs entering and leaving an area. Impinj has a proprietary SDK called Octane SDK and gives some sample Java code. I took one of the sample programs and reformatted it so that it outputs I need in comma separated format. I compiled that sample file (and 2 others it depended on) and put them into the com\impinj\octane folder in the .jar file. I then put the .jar file into Ignition\lib\core\gateway. My question is: how am I able to execute my .class file located in the .jar, called ReadTags?
When I execute ReadTags in Command Line, it opens a connection with the reader and continues giving me data until I press Enter. I’m envisioning something like:
from com.impinj.octane import ReadTagsPeriodicTrigger
reader1 = ReadTagsPeriodicTrigger('10.18.71.100')
I realize that I may have approached this a little abnormally so I’m open to any and all feedback.
Thank you in advance!
EDIT: Modified the code to remove a . in line 2
