Hello everyone,
I have two gateways (gateway 1 with an SQL database and gateway 2 without any database, both of them are remote gateways). Is it possible to execute named queries on gateway 2 and from that be able to have access to the gateway 1 database?
Because I do not have access to database gateway 1 on gateway 2 I do not know how to do this.
Thank you!
I did make a connection between my gateways; however, I would like to have access to the database of gateway 1 on gateway 2. I tried tag history as well but that does not work for my application. I want to be able to query for that database from the 2nd gateway not sure how much feasible is this?
i dont know:/ ive not tried gateway networks yet, in the doc they dont really mention the db connections, but the tag histroy should definitly work tho.
maybe try a diagnostics? see if you succeed in everything there
The tag history works, I do see the connection; however, with tag history, I am not able to query from the database.
This isn’t possible. You can define remote providers for history, tags, etc… but there is no “database proxy” functionality.
Thank you for your response, @Kevin.Herron
Though you cannot do it directly, I think you could use message handlers in the gateways and leverage system.util.sendMessage to from your database-less gateway to the gateway with the database connection and have it return the data.
if you go the way to defining messagehandleers might as well just add a db connection to the other gateway then
