Executing python expression from module
I’d like to execute a python expression and get the result as a String from inside my module. There is a swing component which has dynamic title. Let’s say, I pass python expression ‘now(1000)’, without quotes, through property editor and the title will be dynamically showing datetime string.
According to the answer from @Carl.Gould at this thread I have created a ScriptRunner class.
public class ScriptRunner {
    private final Logger logger = LoggerFactory.getLogger(getClass());
    private final ScriptManager scriptManager;
    public ScriptRunner(ScriptManager scriptManager) {
        assert scriptManager != null : "ScriptManager cannot be null";
        this.scriptManager = scriptManager;
    public String runIt(String scriptCode) {
        if (StringUtils.isBlank(scriptCode)) {
            logger.debug("runIt(ScriptCode) is null or empty");
            return "";
        PyObject compiledScript =
                Py.compile_command_flags(scriptCode,
                        "<whatever-filename>",
                        CompileMode.eval,
                        CompilerFlags.getCompilerFlags(),
                        false);
        try {
            return scriptManager.runFunction(compiledScript).asString();
        } catch (JythonExecException | NullPointerException e) {
            logger.error("Error running {}", scriptCode, e);
        return "NO_RESULT";
I get an instance of the ScriptManager from the component by calling:
VisionClientContext context = getAppContext();
ScriptManager scriptManager = context.getScriptManager();
this.scriptRunner = new ScriptRunner(scriptManager);
Unfortunately, when I call scriptRunner.runIt("now(1000)") I get an exception:
com.inductiveautomation.ignition.common.script.JythonExecException: TypeError: 'tablecode' object is not callable
	at org.python.core.Py.TypeError(Py.java:235)
	at org.python.core.PyObject.__call__(PyObject.java:316)
	at org.python.core.PyObject.__call__(PyObject.java:357)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:670)
	at mycompany.ScriptRunner.runIt(ScriptRunner.java:35)
Could help figuring this out?
Thanks in advance,
Almer
now() is part of our expression language, which is an entirely separate thing from executing arbitrary Jython code.
Hi @Kevin.Herron ,
I am new to Ignition platform. I might have mis-explained my problem. What if I only want to execute Ignition expressions and get back the results as string, for example?
This post may be helpful. You can ignore the alarm-specific parts, but basically what you need is an ExpressionParseContext. Searching for that term yields a couple other results too.
Hi @Kevin.Herron,
thanks, I got it working using this class you wrote and this usage example.
In case if anyone needs a running example, I will leave the following code snippets here:
public class CustomParseContext implements ExpressionParseContext {
    private final TagManagerBase tagManagerBase;
    private final FunctionFactory functionFactory;
    public CustomParseContext(TagManagerBase tagManagerBase, FunctionFactory functionFactory) {
        this.tagManagerBase = tagManagerBase;
        this.functionFactory = functionFactory;
    @Override
    public Expression createBoundExpression(String path) throws RuntimeException {
        try {
            TagPath tagPath = TagPathParser.parse(path);
            Tag tag = tagManagerBase.getTag(tagPath);
            if (tag == null) throw new TagNotFoundException(tagPath);
            TagValue tagValue = tag.getAttribute(tagPath.getProperty());
            TagListener listener = new TagListener(
                    tagPath,
                    tagValue.getValue(),
                    tagValue.getQuality()
            Class type = TagProp.Value.equals(tagPath.getProperty()) ?
                    tag.getDataType().getJavaType() :
                    tagPath.getProperty().getType();
            BoundTagExpression expression = new BoundTagExpression(tagPath);
            expression.setType(type);
            expression.setTagListenerDelegate(listener);
            return expression;
        } catch (IllegalArgumentException | IOException | TagNotFoundException e) {
            throw new RuntimeException(e);
    @Override
    public FunctionFactory getFunctionFactory() {
        return functionFactory;
public class MyComponent extends AbstractVisionPanel {
    @Override
    protected void onStartup() {
        super.onStartup();
        VisionClientContext appContext = getAppContext();
        FunctionFactory functionFactory = appContext.getExpressionFunctionFactory();
        ClientTagManager tagManager = appContext.getTagManager();
        CustomParseContext customParseContext = new CustomParseContext(tagManager, functionFactory);
        Parser parser = new ELParserHarness();
        String expressionString = "now(1000)";
        try {
            Expression expression = parser.parse(expressionString, customParseContext);
            expression.connect(appContext, () -> {
                try {
                    logger.debug("updating");
                    String value = TypeUtilities.toString(expression.execute().getValue());
                    System.out.printf("value = %s\n", value);
                } catch (ExpressionException e) {
                    logger.warn("Error parsing expression '{}'", expressionString);
            expression.startup();
            // Execute the expression 'now(1000)' once
            System.out.println("execute: " + TypeUtilities.toString(expression.execute().getValue()));
        } catch (Exception e) {
            logger.error("Error starting ELParser", e);
I will mark this question as solved if you don’t mind
