With Ignition 8.0.12
In a tag value change script:
import sys
if initialChange == 1:
sys.exit()
if currentValue.value == 0:
sys.exit()
Produce that error in the logger:
Any ideas?
sys.exit() is documented to kill the entire application. Obviously, Ignition doesn’t allow that. That it worked to exit certain kinds of event scripts was always a fluke. Don’t use it. Use return. If you aren’t in function context, delegate to a script module function where return will work.
