Hey,
I am running an Edge Gateway with version 8.1.35.
A customer discovered that sometimes it is not possible to exit login via the "EXIT LOGIN" button. The session deadlocks in a loading screen on step "Connecting". The only way to get out of it is to leave the session, which means to turn off and on the device a focused window.
I can not reconstruct this in my test lab (pretty much same setup), but I was able to get the logs from this project. These logs are coming while the login and exit login process:
| timestmp | formatted_message | logger_name | level_string |
| 1732722656001 | /system/pws/HMI_POD/33bdf30e | org.eclipse.jetty.server.HttpChannel | WARN |
| 1732722633567 | WebSocket disconnected from session. | perspective.ClientSession | INFO |
| 1732722628963 | Shutting down delegate for '0:0:3'! | com.inductiveautomation.perspective.ComponentModel | INFO |
| 1732722628963 | Shutting down delegate for '0:0:1'! | com.inductiveautomation.perspective.ComponentModel | INFO |
| 1732722598785 | Starting up delegate for '0:0:3'! | com.inductiveautomation.perspective.ComponentModel | INFO |
| 1732722598785 | Starting up delegate for '0:0:1'! | com.inductiveautomation.perspective.ComponentModel | INFO |
| 1732722570227 | Created auto-backup of internal database "config.idb" in 989 ms | Platform.InternalDatabase | INFO |
| 1732722569238 | Creating auto-backup of internal database "config.idb"... | Platform.InternalDatabase | INFO |
| 1732722569076 | WebSocket disconnected from session. | perspective.ClientSession | INFO |
Did somebody else noticed this behavior or has an idea how to solve this? I could not find something in the forum so far.
