The expansion or description symbol '+' is not available in the Gateway Diagnostics Logs for Error logs since sometime. But previously it was available as shown below
What is needed:-
How it is now:-
Any idea how to make the expansion button re-appear ?
The expansion is only available if the associated message was logged with a Java throwable attached; there's no guarantee because of how you cropped your screenshot that the messages you're looking at had any associated logged exception.
If it's the exact same logged message on both sides, do you have any browser extensions or anything that might be blocking the element? You can export the logs and open them in Kindling to get a full insight into the underlying logged data.
Thank you @PGriffith ,
But those are just Gateway Tag event script errors which previously was expandable for details. Like the one below
I'm facing this issue in only one of the Gateway, in another Gateway log the expansion button is still visible for Gateway Tag event script errors and other errors like shown below. Here I have a Wrapper Error as example though.
Does anyone know why the expansion is not working for the same type of logged messages in the Gateway log itself ?
