Expected parameter error
Hi , When i start the configuration it gives me error “Expected parameter @datetime” which was not supplied. But in my configuration i am binding it with OPC item.
What version of FactorySQL are you using, and what database system? SQL Server?
In your OPC item, are you specifying the “datetime” parameter with or without the “@” character (note: it normally shouldn’t matter, as the system should detect it, but I’m just curious).
Regards,
Factory SQL version 4.2.11(demo version) . Database is SQL server 2000.I tried both ways with and without ‘@’ .I face this issue only when i am using remote database if i use my local database ,same configuration works fine .
if u required any further information please let me know .
Regards
Hi ,
sorry it was issue with my connection string . sorry for the inconvinence .
Regards
No problem, glad you got it working. Thanks for following up, seems like a strange way to report a connection problem.
Regards,
