I have put a dataSet on Parameters,
and I would like export then on excel/CSV file.
dataDS = self.view.params.pData #table.data
system.dataset.exportExcel("test.xls",1, dataDS)
error:
com.inductiveautomation.ignition.common.script.JythonExecException
File "<function:runAction>", line 3, in runAction
TypeError: can't convert u'value' to com.inductiveautomation.ignition.common.Dataset
caused by org.python.core.PyException
Ignition v8.1.38 (b2024030513)
Java: Azul Systems, Inc. 17.0.9
First time I'am tryng to export data. someone can help ?
You are trying to export a string value to excel. The exportExcel system function expects a dataset.
headers = ['test']
data = [['value']]
dataDS = system.dataset.toDataSet(headers,data)
Thank you @dkhayes117
I do this script but I'am getting another error:
headers = []
data = []
DS = self.parent.parent.parent.getChild("CorpEvenement").props.params.Data
for row in DS:
if not headers:
headers = row.keys()
data.append([val for key,val in row.iteritems()])
dataDS= system.dataset.toDataSet(headers,data)
#dataDS = self.parent.parent.parent.getChild("CorpEvenement").props.params.Data #table.data
errror:
File "<function:runAction>", line 16, in runAction
AttributeError: 'com.inductiveautomation.ignition.common.script.Imm' object has no attribute 'exportExcel'
at org.python.core.Py.AttributeError(Py.java:176)
at org.python.core.PyObject.noAttributeError(PyObject.java:965)
at org.python.core.PyObject.__getattr__(PyObject.java:959)
at org.python.pycode._pyx1905.runAction$1(<function:runAction>:16)
at org.python.pycode._pyx1905.call_function(<function:runAction>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1010)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:950)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:161)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:98)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:80)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:263)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:252)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:221)
at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException
... 29 more
exportExcel() will not work in perspective. Use toExcel() instead.
I missed the perspective tag
I'am gatting the same error
TypeError: can't convert 1 to com.inductiveautomation.ignition.common.Dataset
toExcel has different parameters and return value.
Pause.
Take a second.
Use the autocomplete (Ctrl+Space).
Try to solve your own problems.
WOW.............
WHY WAS THIS HIDDEN FROM ME........
I will forever use this:
hello @paul-griffith
I used what you recomanded me but, it not work. But maybe I forgot something
this my dataset:
scrip:
DS = self.view.getChild("root").custom.DataStatusAlarmes
headers = system.dataset.getColumnHeaders(DS)
system.dataset.toExcel(headers, DS, "C:\\TESTE\\results1.xls")
I get this error:
File "<function:runAction>", line 6, in runAction
TypeError: can't convert [u'62d04597-0f49-4930-80f5-2d302efa155f', u'prov:default:/tag:Sensor/Sensor7/F8:/alm: High Alarm', u'Sensor 7 High Alarm', Wed May 08 15:13:42 CEST 2024, 0, 3] to com.inductiveautomation.ignition.common.Dataset
at org.python.core.Py.TypeError(Py.java:236)
at org.python.core.Py.tojava(Py.java:568)
at com.inductiveautomation.ignition.common.script.builtin.DatasetUtilities.lambda$toExcel$1(DatasetUtilities.java:1022)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.Iterator.forEachRemaining(Unknown Source)
at java.base/java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluateToArrayNode(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.toArray(Unknown Source)
at com.inductiveautomation.ignition.common.script.builtin.DatasetUtilities.toExcel(DatasetUtilities.java:1022)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:208)
at org.python.core.PyObject.__call__(PyObject.java:494)
at org.python.core.PyObject.__call__(PyObject.java:498)
at org.python.pycode._pyx1823.runAction$1(<function:runAction>:27)
at org.python.pycode._pyx1823.call_function(<function:runAction>)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:846)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:828)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:832)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1009)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:897)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:158)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:97)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:74)
... 46 more
Ignition v8.1.27 (b2023042509)
Java: Azul Systems, Inc. 11.0.18
I found solution using: spreadsheet = system.dataset.dataSetToExcel(1, [DS]) and system.file.writeFile(filePath, spreadsheet)
It work.
For a simple export to.csv and download this works onClick Event
def runAction(self, event):
component = self.getSibling("tblWorkRequest")
# Convert the dataset to CSV
csv = system.dataset.toCSV(component.props.data)
# Initiate a file download
system.perspective.download("solicitudesOT.csv", csv)
tblWorkRequest is the table name, use the hierarchy u need.
Hi Alejandro,
Yes this works.
but when I open the CSV
all the data points are concentrated in a 1 cell.
is there a way to fomat the csv before exporting to csv?
Hello!
You may try:
# Convert the dataset to CSV using commas as delimiter
csv = system.dataset.toCSV(component.props.data, 1)
Thanks Alejandro,
Do you have the link for the manual for this script function?
No, I don´t have a Manual for this, you may research online.
it fixes the 1 concentratrated cell issue but it puts all table data in 1 row
You may research online or in this forum.
try:
# Encode as UTF-8 with proper line breaks
csvBytes = csv.encode('utf-8')
system.perspective.download("solicitudesOT.csv", csvBytes)
Cheers!
Hi Everyone,
I am facing some issues in system.perspective.toExcel function where I am getting the below error
at com.inductiveautomation.ignition.common.util.excel.adapters.DatasetExcelAdapter.drawSheet(DatasetExcelAdapter.java:61)
at com.inductiveautomation.ignition.common.util.excel.adapters.DatasetExcelAdapter.drawWorkbook(DatasetExcelAdapter.java:44)
at com.inductiveautomation.ignition.common.script.builtin.DatasetUtilities.dataSetToExcelBytes(DatasetUtilities.java:1217)
at com.inductiveautomation.ignition.common.script.builtin.DatasetUtilities.toExcel(DatasetUtilities.java:1031)
The same daatset can be converted into csv so data has no issues, i suspect something to do with excel formating.
Please suggest a way forward
To export to excel, for example a table you may use something like:
ds = self.getSibling("TablaDNF_0").custom.datatable
# Convertir a Excel
excelBytes = system.dataset.toExcel(True, [ds])
# Descargar archivo
system.perspective.download("kWh_GEN_ConsumoEdificiosINFRA.xls", excelBytes)
