Is it possible to export/import a dataset to/from a string (instead a .csv file)?
I want to save the complete dataset as string in a database field.
The dataset type is serializable, so that would be a possibility: wrap a ByteArrayOutputStream in an ObjectOutputStream, use writeObject() to fill the byte array with the serialized dataset, then save the bytes to a suitable database column.
An alternative is to use java.beans.XMLEncoder … I’ve played with this, but not enough to recommending it yet
The StringIO module should be good for this.
Easy enough to encode the dataset into a csv string. The issue may be when you pull it back out and need the original data types.
The attached window strives to overcome that.
CSV Strings_2017-06-27_1053.proj (44.7 KB)
Hopefully, this will give you some ideas.
[quote=“pturmel”]The dataset type is serializable, so that would be a possibility: wrap a ByteArrayOutputStream in an ObjectOutputStream, use writeObject() to fill the byte array with the serialized dataset, then save the bytes to a suitable database column.
[/quote]
That worked perfectly!
[quote=“JordanCClark”]The StringIO module should be good for this.
[/quote]
I’ll also try this!
