Is there a way to export/import Alarm Notification Profiles and Users/Roles from one Gateway for use in another Gateway?
Unfortunately no, the only way to do this is with a gateway backup.
Has there been any activity on this? I find myself in a situation where I need to export the hundreds of users and roles and import them en masse to another Gateway.
If you are brave, you can use a SQLite DB browser to extract the relevant data from config.idb and inject it into the new system. Make sure you handle the table containing sequence numbers. Utterly unsupported, of course.
( Make good backups first! )
