Export/Import project using command lines
I am looking for a way to export or import a project using some command lines. I found nothing on the Gateway Utility.
The only export I see is creating backup .gwbk. An alternative could be to “extract” projects from a .gwbk file, but I dont think it is possible?
In 8.x you can simply unzip a project export into the correct location in the data folder.
In 7.x I don’t think there’s any solution for you.
Also, .gwbk files are just renamed .zip files. Any tool that can read a zip file can read a .gwbk, and 8.X projects are plain files directly inside the zip; should be relatively trivial to script an extraction job.
Once you've unzipped a project export in the data folder, do you still have to wait for the Gateway sync/scan time to pick up your changes? I think the current default is 300 seconds.
Is there anyway to force it to re-scan immediately?
Thanks.
-Shane
8.1.28 added system.project.scan()
Assuming you meant:
https://docs.inductiveautomation.com/display/DOC81/system.project.requestScan
Oops, yes, I was reading from the original description in the issue tracker, didn't notice it got changed to requestScan.
Can it be called from a third party application? (version control system / ~GIT)
No, not directly. You could set up a WebDev endpoint or something and do it that way, though.
