I have this script on a button but it doesn’t work.
table = event.source.parent.getComponent("Table")
filePath = system.dataset.exportExcel("data.xls", 1, table)
if filePath != None:
system.net.openURL("file://"+filePath)
when I push the button this happen
The excel was created but when I tried to open it it says It can’t read.
MoisesZV
you only want the table data
filePath = system.dataset.exportExcel("data.xls", 1, table.data)
thanks now is working but still get this error “illegal character in authority at index 7” when I create the file.
Things changed (in Java, I think) with how openURL works. It’s now a lot less friendly.
Doug Keller had a working solution in this post.
[quote=“JordanCClark”]Things changed (in Java, I think) with how openURL works. It’s now a lot less friendly.
Doug Keller had a working solution in this post.[/quote]
Thanks Jordan! that solved my problem.
