Exporting .proj project to later import it from another gateway
Hello!
In order to import a project in my main gateway from another gateway I need the .proj file....but in my current gateway when I do export the project it only gives me the option to export it as a .zip file.
I would like to know if there is a way to export my project as .proj so I can later import it on the main server gateway.
Cheers!
.proj is the import format for 7.9 and earlier gateways. .zip is the import format for 8.0+ gateways. If you're exporting .zip and trying to import .proj, you're trying to go backwards in time, which won't work.
