I followed this IU tutorial:
Exporting Data to CSV Video at Inductive University
to create a button that exports data from a table to a CSV file, but I get an error when I run it. I didn't make any changes to the script compared to what was used in the video, but when I try to use the button, I get this error message:
Error running action 'dom.onClick' on orderStatus/open-sales-orders@D/root/Button: Traceback (most recent call last): File "function:runAction", line 3, in runAction AttributeError: 'com.inductiveautomation.ignition.common.script.ada' object has no attribute 'source'
Here is my code for reference:
def runAction(self, event):
#get table data as a dataset
dataset = event.source.parent.getComponent("Table").data
#convert dataset to multi-line csv string
csv = system.dataset.toCSV(dataset)
#prompt for desired file location
file = system.file.saveFile("export1.csv")
#intercept any cancel case, then write to file
if file:
system.file.writeFile(file, csv)
I assume the "event" object is referening to the "onClick" mouse event, but I do not understand what the ".source" or ".parent" objects/attributes are referring to. What I am wondering is if I made an error somewhere or if this code may no longer be valid and I need to use something else?
Any script that uses event.source is a script intended for Vision, not Perspective. You cannot cut and paste it into a Perspective action and expect it to work.
The function system.file.saveFile() doesn't work at all in Perspective, as Perspective cannot open a file save dialog on a client like that. The system.file.writeFile() function writes to the gateway filesystem, not a client filesystem, as Perspective scripts run in the gateway.
The technique needed in Perspective is the use of system.perspective.download(). Numerous examples on this forum.
Nathan, here's a script I wrote to download table data into an .xlsx format. That, along with what pturmel wrote, should give you a good understanding of how this is accomplished.
dataset = self.parent.parent.getChild("TabContainer").getChild("Downtime Log").props.data
download = system.dataset.toExcel(1, dataset)
date_start = self.getSibling("StartDate").props.value
date_range = self.getSibling("DateRange").props.value
if date_range == 1:
date_end = system.date.addDays(date_start, 1)
elif date_range == 2:
date_end = system.date.addWeeks(date_start, 1)
elif date_range == 3:
date_end = system.date.addMonths(date_start, 1)
now = system.date.now()
if date_end > now:
date_end = now
date_start_formatted = system.date.format(date_start,"yyyy-MM-dd")
date_end_formatted = system.date.format(date_end,"yyyy-MM-dd")
system.perspective.download("Downtime Export "+date_start_formatted+" to "+date_end_formatted+".xlsx", download)
Granted, this downloads the data in .xlsx format, but the process is very similar for CSV.
Ah, I didn't know it was a vision script in the video I only have perspective on my license and haven't ever used it. That would makes sense as to why I couldn't find much information in the manual. Thanks for the help.
I was able to adapt this script to get it working. Thanks a lot for the example!
