Exporting table to .csv with formated columns?
Hello!
Anibody has solve or has an idea on how to export a .csv in Ignition with formated columns so everithing doesn´t appear on just 1st column of the .csv. I would need this so my client can make reports on the table data.
At the moment I got:
# Get table
table = self.parent.getChild("TabContainer").getChild("ColumnContainer_1").getChild("TablaDNF_3")
# Use raw dataset
ds = table.props.data
# Convert dataset to CSV (semicolon for Excel)
csv_string = system.dataset.toCSV(ds, showHeaders=True, delimiter=';')
# Force Windows line endings (\r\n)
csv_string = csv_string.replace("\n", "\r\n")
# Add UTF-8 BOM for Excel compatibility
csv_bytes = u'\ufeff'.encode('utf-8') + csv_string.encode('utf-8')
# Download file with static name
system.perspective.download("TablaDNF.csv", csv_bytes)
But still showing all in same 1st column.
Any ideas our workarounds welcome. I´ve got many tables to export. for reports
Thank you!
Change the delimiter to a comma. Or don't specify it in the toCSV function
I've never needed to do that to open property in Excel.
Thanks @bschroeder
I tried with "," but doesn´t seem to work
can you suply what code to use for button?
I tried many ways and can´t make it work.
What part doesn't work? When you open the file in excel everything is in a single line?
If you open the file in a text editor, are the fields delimited with a comma?
I would honestly take out all the encoding stuff to make sure there isn't another issue happening.
# Get table
# Use raw dataset
csv_string = system.dataset.toCSV(ds)
system.perspective.download("TablaDNF.csv", csv_string )
See if you get a file that looks like a CSV.
Why not just use system.dataset.toExcel() ?
I've never had an issue importing a CSV using a comma as the delimeter into excel. I've also never needed to do anything extra to make the file "compatible" such as converting new line characters.
Can you provide a sample of what your table looks like and what the resulting CSV looks like?
Thanks Irose,
I´m using code:
  	component = self.parent.getChild("TabContainer").getChild("TablaOT")
	csv = system.dataset.toCSV(component.props.data)
    # Get the current date
	current_time = system.date.now()
    # Format the date into a string for the file name (e.g., "YYYYMMDD")
	formatted_date = system.date.format(current_time, "yyyyMMdd")
	file_name = "TablaOT_" + formatted_date + ".csv"
	system.perspective.download(file_name, csv)
to export a table like:
i getting a csv file like:
with all the data for each row compacted in first column
You get the data well formated in different columns?
If can use excel directly that would be great, let me know if this code looks good for you, and if not please provide a simple version to export a simple table, that would be enough for me to work with.
Cheers!
Is your table data a dataset or a JSON?
If your end customer can use a native file type, then I would use the toExcel rather than the toCSV.
See the manual: system.dataset.toExcel | Ignition User Manual.
But you should be able to replace your toCSV with the toExcel function, and everything else should work fine.
You can see from the CSV file that there is no formatting information embedded in the file. It supplies each row of the table on a separate line and defaults to comma separatation (CSV = Comma-Separated Variable). Usually strings are "quoted" and numbers are not. Your sample seems to show everything quoted.
Your user can very quickly convert to columns:
This, really. Don't use CSV if you need formatting in Excel. CSV is fundamentally unformatted.
If system.dataset.toExcel() doesn't produce acceptable formatting, you can use the Apache POI libraries (included with Ignition) to implement your own custom export. (Multiple examples here on the forum.)
def runAction(self, event):
		ds = self.parent.getChild("TabContainer").getChild("TablaDNF_2").props.data
		# Convertir a Excel
		excelBytes = system.dataset.dataSetToExcel(True, [ds])
		# Descargar archivo
		system.perspective.download("TablaDNF.xls", excelBytes)
This seem to work exporting the table to excel with formated columns in Ignition Perspective 8.1.38 on a simple table without any styling.
Thanks everibody for your help!
This should be system.dataset.toExcel()
You can avoid the messy syntax.
  • On the view, create custom.tableData.
  • Put the data binding on that.
  • Bind the table's data property to that.
  • Now your code becomes ds = view.custom.tableData and it will still work if you move the table in or out of a container.
yes, work with both toExcel() and dataSetToExcel()
There is no function system.dataset.dataSetToExcel()
It actually works, as seen on post:
I think it´s a combination of:
data = system.dataset.toDataSet(header, data)
data = system.dataset.toExcel(True, [data])
The function has been deprecated, and should not be used in new code. system.dataset.toExcel() is the correct function to be used.
Ok, thank you!
final simple solution:
		# Convertir a Excel
		excelBytes = system.dataset.toExcel(True, [ds])
		# Descargar archivo
