When exporting the tag db an error occurred  (TAG"types"not found).  When bypassing and selecting all the folders except for the data types folder it works.  The  data type folder is empty.
Also, I did see an issue with the csv file.  All of the tags are located within  folders however, one of the folders tags for some reason, got duplicated and resided outside of the folder.  Tried to reproduce but was unsuccessful.
Thanks for posting this. Apparently there is an issue if you’ve never created a datatype. If you make one (even if you then delete it), you shouldn’t get this error.
We’ll take a look and get it fixed for the next update.
Regards,
This will be fixed for 7.4.2.
Regards,
