You can import PMITreeView’s beaninfo for your subclass. Here’s the BeanInfo code for the NoteChart class for your edification, and likely pre-emption of your next question. (-:[code]/* Filename: NoteChartBeanInfo.java
- Created on Jan 3, 2015
- Author: Phil Turmel pturmel@automation-pros.com
- Copyright Automation Professionals, LLC 2015
- Project: NoteChart_Designer
package com.automation_pros.notechart.beaninfos;
import java.awt.Image;
import java.beans.BeanDescriptor;
import java.beans.BeanInfo;
import java.beans.IntrospectionException;
import java.beans.SimpleBeanInfo;
import javax.swing.ImageIcon;
import com.automation_pros.notechart.components.NoteChart;
import com.inductiveautomation.factorypmi.designer.beaninfo.PMIChartBeanInfo;
import com.inductiveautomation.factorypmi.designer.property.customizers.ChartCustomizer;
import com.inductiveautomation.vision.api.designer.beans.CommonBeanInfo;
import com.inductiveautomation.vision.api.designer.beans.CustomizerDescriptor;
import com.inductiveautomation.vision.api.designer.beans.VisionBeanDescriptor;
public class NoteChartBeanInfo extends CommonBeanInfo {
public NoteChartBeanInfo() {
super(NoteChart.class, new CustomizerDescriptor[] {
ChartCustomizer.VALUE_DESCRIPTOR });
getBeanDescriptor().setValue("dbl-click-customizer", ChartCustomizer.VALUE_DESCRIPTOR.getValueName());
@Override
protected void initProperties() throws IntrospectionException {
// Adds common properties
super.initProperties();
// Remove properties that NoteChart will define differently from CommonBeanInfo
removeProp("opaque");
// Add all notechart-specific properties
addProp("notes", "Notes", "Dataset of text annotations to display",
CAT_DATA, PREFERRED_MASK | BOUND_MASK);
addProp("altNotes", "Alternate Notes", "Dataset of alternate annotations for live modifications",
addProp("samples", "Pen Value Samples", "Dataset of pen values at the Trace timestamp (when visible)",
addProp("traceTS", "Trace Timestamp", "Timestamp for the selected annotation, or independent trace if no selection",
addProp("selectedNote", "Selected Note", "Row Number of the selected Note within the Notes dataset",
addProp("selectedAltNote", "Selected Alternate Note", "Row Number of the selected Alternate Note within the Alternate Notes dataset",
addProp("noteFont", "Annotation Font", "Font for all text annotations",
CAT_APPEARANCE, PREFERRED_MASK);
addProp("noteColor", "Annotation Color", "Color of text annotations that lack a specified color",
CAT_APPEARANCE, NO_MASK);
addProp("noteStroke", "Annotation Stroke", "Line Style for all unselected text annotations",
CAT_APPEARANCE, EXPERT_MASK);
addProp("selNoteColor", "Selected Annotation Color", "Color for a selected annotation",
addProp("selNoteStroke", "Selected Annotation Stroke", "Line Style for a selected annotation",
addProp("prioThreshold", "Priority Threshold", "Maximum Number of Notes to Display without priority filtering",
CAT_BEHAVIOR, EXPERT_MASK);
addProp("enableNoteSelect", "Enable Note Selection", "Annotations can clicked (at their text) to set selectedNote or selectedAltNote",
/* Hide properties from PMIChart that NoteChart can't use. They
* would show up from getAdditionalBeanInfo().
addProp("chartType", "Must be an XY Chart", "", CAT_BEHAVIOR, HIDDEN_MASK);
addProp("subplotMode", "Must be Combined Domain", "", CAT_BEHAVIOR, HIDDEN_MASK);
@Override
public Image getIcon(int kind) {
switch (kind) {
case BeanInfo.ICON_COLOR_16x16:
case BeanInfo.ICON_MONO_16x16:
return new ImageIcon(getClass().getResource("/images/note-chart_16.png")).getImage();
case SimpleBeanInfo.ICON_COLOR_32x32:
case SimpleBeanInfo.ICON_MONO_32x32:
return new ImageIcon(getClass().getResource("/images/note-chart_32.png")).getImage();
return null;
@Override
protected void initDesc() {
VisionBeanDescriptor bean = getBeanDescriptor();
bean.setName("Classic Note Chart");
bean.setDisplayName("Classic Note Chart");
bean.setShortDescription("A component that displays time-series Plots with annotation marks.");
BeanInfo superbi = new PMIChartBeanInfo();
BeanDescriptor superbean = superbi.getBeanDescriptor();
bean.setValue("vision-extension-functions", superbean.getValue("vision-extension-functions"));
@Override
public BeanInfo[] getAdditionalBeanInfo() {
BeanInfo[] superbi = { new PMIChartBeanInfo() };
return superbi;
}[/code]
