Hello,
We are running an issue into our Ignition Gateway 7.9.
We are lazily injecting OPC parameters from an UDT into his tags with, for each of them, this expression binding:
Path: {{PathToParentFolder}.Path}
Server: {{PathToParentFolder}.Server}
Tag: {{PathToParentFolder}.Tag}
Etc…
This is working well.
However, we are getting many errors in the log file when we start the gateway such as this one:
Error expanding sub parameter reference ‘[PARAMETER-NAME]’ in tag ‘[TAG-NAME]’
java.lang.Exception: Expecting close delimiter '}' but found: 'PathToParentFolder'
at com.inductiveautomation.ignition.common.expressions.parsing.StringParser.parseQueryWithBoundPathsNoEscape(StringParser.java:184)
I think this is because the string parser doesn’t expect more than 1 pair of {}.
However, this is the only way we found to bind the UDT parameters to the tags.
First one is for the expression binding and second one is for using the {PathToParentFolder} pre-defined parameter.
Do you have a solution?
