Hi , i am trying to make a kind of machine diagnosis using studio5000 and ignition…
so if the machine is at step 1 and need two more sensor to be ON to go at step 2 id like my diagnosis to write down these 2 sensor with breakline between the two.
i am using a ‘text area’ and the following expression
So in other word if X =1 it will show string 1 and if Y is also 1 it will show string 2 right after string 1…
and it will show like this :
string 1 sting 2
but if i have multiple diagnosis , text will be too longue so id like my text to be like this
string 1
string 2
i googled it like 3hours and i found ‘\n’ , \ or “\n” but none of them seems to work in ignition
(sorry if my english is bad a little im french im doing my best)
Hey Chris , thanks for your fast answer !
when i paster the code in binding expression box and pressed apply an error message showed saying something like “illegal character on line 3”
It was working but it was putting lots of breakline one after the other so i got tons of spaces between my diagnosis
so i modified it like that and its working great
