Expression Comparisons
In Python you can say:
if 2 < 3 < 4:
print ‘Hello’
and it will be very clear and it will work.
In expression language if you say:
if( 2 < 3 < 4, ‘Hello’, ‘Goodbye’)
it will give you an error because it can’t compare three values like that.
The best way around this I have found is:
if( 2 < 3 && 3 < 4, ‘Hello’, ‘Goodbye’)
but in practice and for longer comparisons it quickly becomes less clear than the Python version.
if( myVal1 < myVal2 && myVal2 < myVal3 && myVal3 < myVal4, ‘Hello’, ‘Goodbye’)
Is there another way to do this or has Python spoiled me?
Any ideas are appreciated.
Thanks,
  • Mike
Python has spoiled you. :laughing:
I’ve never used it before but I believe the switch function will handle multiple evaluations and returns.
If you really must, you can do this with python via objectScript() or the latest runScript():objectScript('args[0] < args[1] < args[2]', {Root Container.property1}, {Root Container.property2}, {Root Container.property3})Though I doubt I’d actually do this unless one or more of the arguments had execution side effects or big delays.
{ /end shameless plug for one of my modules :laughing: }
I have 3 LED Displays that have a script changing them to a 1 or 0 in the value that in turn changes the text. I now need to check each LED data value field to see if they are all 1's, if they are it will will return true (1) and enable a button, if any 1 of the 3 fields are 0, it should return a false (0) and not enable the button. I have tried multiple ways but cannot seem to get the statement right.
Current statement:
If({Root Container.Displacement Display.value} = {Root Container.Generic Indicator.value} = {Root Container.Serial Number LED Display.value},1,0)
Change the expression to a simple logical AND.
  && {Root Container.Generic Indicator.value}
  && {Root Container.Serial Number LED Display.value}
That will return a boolean true or false.
Expression functions work a little like Excel formulas (but without the = operator at the start).
Tip: use the </> button when posting code. It preserves tabs, does syntax highlighting and makes it obvious where the code starts and ends.
I implemented these a while ago, but seeing this topic pushed me to release an update to Ignition Extensions that adds an anyOf expression function that could be useful for collapsing repeated boolean checks.
Thank you transistor. This is working like I hoped. Is there a way to bind this boolean to a button enable/disable. I have been trying to use this to enable a button but have been unsuccessful. If the boolean is a 1 the button is on and if 0 the button is disabled.
Will the expression not work in the enable property?
It does not seem to in the format Transistor gave me. I also tried an if statement with Transistors syntax with the same results. When you say enable property do you mean the set property?
HaHa! I'm a newb. I found it in the filter for the vision property filter for all instead of Basic.
Thank you Jordan.
