why do i keep getting this error when the data changes for this expression? if I take out the round it works fine with no error.
if(toint({Root Container.Container_1.lblDist2YearsAgo.text},0)=0,0,round(toint({Root Container.Container_1.txtSales2YearsAgo.text},0)/toint({Root Container.Container_1.txtDist2YearsAgo.text},0),1))
[quote]ERROR [AbstractPropertyAdapter-AWT-EventQueue-0]
java.lang.Exception: Error executing expression binding on
SalesProjections.Root Container.Container_1.txtSPP2YearsAgo.text
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:65)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.childInteractionUpdated(ExpressionPropertyAdapter.java:45)
at com.inductiveautomation.factorypmi.application.binding.PropertyListenerDescriptor.propertyChange(PropertyListenerDescriptor.java:67)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at java.awt.Component.firePropertyChange(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.PMITextField.access$000(PMITextField.java:27)
at com.inductiveautomation.factorypmi.application.components.PMITextField$1.propertyChange(PMITextField.java:43)
at javax.swing.JFormattedTextField.setValue(Unknown Source)
at com.inductiveautomation.vision.api.client.components.model.BaseFormattedTextField.setValueDirect(BaseFormattedTextField.java:177)
at com.inductiveautomation.vision.api.client.components.model.BaseFormattedTextField.setValue(BaseFormattedTextField.java:172)
at com.inductiveautomation.factorypmi.application.components.PMITextField.setTextImpl(PMITextField.java:67)
at com.inductiveautomation.factorypmi.application.components.PMITextField.setText(PMITextField.java:52)
at sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:260)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:210)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:60)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.fireDynChange(AbstractVisionPanel.java:132)
at com.inductiveautomation.factorypmi.application.binding.util.DynamicPropertyUtil.setPropertyValue(DynamicPropertyUtil.java:217)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.setPropertyValue(AbstractVisionPanel.java:116)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:244)
at com.inductiveautomation.factorypmi.application.binding.SQLPropertyAdapter.updateTarget(SQLPropertyAdapter.java:253)
at com.inductiveautomation.factorypmi.application.binding.SQLPropertyAdapter.handleQueryReturnedValue(SQLPropertyAdapter.java:290)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$HandleReturnValueTask.run(QueryManager.java:518)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
Caused by: java.lang.NumberFormatException: Infinite or NaN
at java.math.BigDecimal.(Unknown Source)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$RoundFunction.execute(DefaultFunctionFactory.java:1017)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$IfFunction.execute(DefaultFunctionFactory.java:1302)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:59)
… 64 more
[/quote]
