Using 7.6.3 in Windows7-64bit.
I defined in system tags an expression tag.
If in Expression property I do
runScript("var1=5")
the value tag is: 5.
runScript("var1=5\nvar1=6")
runScript("var1=5\nVar1=Var1+6\nreturn Var1")
the value tag is: null.
Am I doing something wrong?
It seems that return doesn’t work in the runScript expression.
Even though you can use the newline character ( \n ) to run additional lines of code, it looks like the runScript expression is only returning the evaluation of the first line of code.
I believe you can use return if your first line is a function definition, but I haven’t tested that.
