Expression script question with colours
hello,
In vision you could bind to a color property and change it with
case(
{[Sample_Tags]OPC Custom Tags/Cond1Running}, // value
1, // case 1
color (0,0,0), // return 1
color (92,89,89)) // default
How do i do the same binding to a property in perspective? In the property editor i have bound the above case situation to Props>TextStyle>color but obviously doesnt work.
Whats the correct syntax to bind to a property in perspective
Convert that RGB color to hex.
So instead of color(0,0,0) you would write “#000000” likewise
yea makes sense.
Cheers it worked.
Css can also do a string like this "rgb(250,0,0)"
