Expression Split function does not recognize full stop character
Using the split function in expression with the '.' character return a empty dataset
split("[default]Process/P_01/INLETW/02_WAP/12PC05/Sts/Value.EngHigh",".")
split("[default]Process/P_01/INLETW/02_WAP/12PC05/Sts/Value.EngHigh","/")
This looks like a bug.
Using Ignition Version 8.1.43 (b2024082010)
The split() expression splits on a regex, not a character. The . is not interpreted as a .
It works if you escape the . like so:
split("[default]Process/P_01/INLETW/02_WAP/12PC05/Sts/Value.EngHigh","\\.")
