So I am already aware that you can get a value from a datatset using the expression syntax of {session.custom.Dataset}[{view.params.StepNum}-1, "DataValue"]. I actively use this to grab data for template instances. The problem I am running into is trying to fetch a value from a dataset in an array.
I’ve tried {session.custom.DataArray}[view.params.Instance][{view.params.StepNum}-1, "DataValue"] but that does not seem to work.
I tried changing the array to a dictionary, which did result in {session.custom.DataArray}[view.params.Instance] returning the dataset, but I can’t seem to dig any further than that.
I feel I am missing something extremely simple.
