I’ve searched through the topics but cant find the answer to the following
Im trying to to display my documentation meta data field in the alarm display path
I know I can do this my manually specifiying my tagname.documentation as follows
{[.]TAGNAME.Documentation}
However I want to make this generic for all tags and not have to manually edit the tagname field in each alarm type
{itemname} on its own can show my TAGNAME but how to combine
The following “{[.]”+{itemName}+".Documentation}" just diplays the string {[.]TAGNAME.Documentation} not the contents of it.
I’m trying to do this exact thing, @declan1, were you able to solve this problem?
https://docs.inductiveautomation.com/display/DOC80/Tag+Paths
Tags have a built-in "this" keyword, that can be used as a reference to the tag. The keyword is useful in cases where an expression is being configured on a tag property, and you want to reference the value of another property.
For this case, try:
{this.Documentation}
Awesome! Thank you @bmusson, not sure how I missed that documentation but thank you for the reply and for sharing. I tested it out and it works as expected; thanks again!
