Hello,
I want to add an Expression Tag inside a UDT but the expression I want to write is based in the AlertCurrentSeverity meta property of another OPC Tag inside the same UDT.
It’s something like this:
//UDT:
Pump {
floatOPCtag Temp; //This has analog alerting
floatOPCtag Level; //This also has analog Alerting
intExpressionTag Status;
//Expression for Status:
if(Temp.AlertCurrentSeverity>Level.AlertCurrentSeverity,
Temp.AlertCurrentSeverity,
Level.AlertCurrentSeverity)
Colby gave me some hints using templates here
viewtopic.php?f=71&t=8032
but I can’t get it done using only UDTs
Is there a way to do this?
That’s considerably easier than the last problem. Here’s the expression you want:
if({[.]Temp.AlertCurrentSeverity}>{[.]Level.AlertCurrentSeverity},
{[.]Temp.AlertCurrentSeverity},
{[.]Level.AlertCurrentSeverity})
Basically, in any expression anywhere, you can refer to a tag through “{tagpath}”. A tag path can be relative or absolute, and the example above simply has the relative root source definition, “[.]”, required for referencing things inside of the UDT (the relative “[~]” would also work).
Anyhow, once you can reference a tag, you can reference a property of that tag through “.prop”.
Regards,
Ahhhhh That is great!
I always get surprised of the simplicity of your answers!
Thanks a lot!!
