This is an expression, not scripting.
{[.]Line} is a tag reference.
You could replace 1 with similar syntax referencing some OPC tag.
You should probably do some reading or watch some IU videos re: expressions and scripting.
You could also convert them to case | Ignition User Manual statements which are a bit easier to read.
case(
{[.]Line},
"LineA", 1,
"LineB", 2,
"LineC", 3,
"LineD", 4,
Note that the original expression is inconsistent. In one case it returns a string, "-" and in all the others it returns an integer. This is likely to cause problems elsewhere. (My expression does the same as it's merely a conversion from switch to case.)
Tip: for future code questions, please see Wiki - how to post code on this forum.
