How can I get a window's parent desktop mode (windowed or fullscreen) from an expression?
Parent desktop? Is it even possible to have different desktops in different modes?
This sounds like runScript territory. If I understand what you are asking correctly, it seems like you could do it by calling your Nav.desktopIsWindowedMode library script using self.parent as the argument from a custom property on the root container.
What do you need this for? Whatever it is, I feel like there should be a better approach than using a runScript expression.
Yes. This is my script on a button.
desktop = Nav.getParentDesktop(system.gui.getParentWindow(event))
if Nav.desktopIsWindowedMode(desktop):
Nav.desktopSwapDisplayMode(desktop)
else:
Nav.desktopSwapDisplayMode(Nav.openNewDesktop())
def getParentDesktop(window):
Get the parent desktop JFrame for supplied window.
Args:
window (obj) : window on the desktop
Returns:
desktop (JFrame) : window's parent desktop JFrame
while not isinstance(window, JFrame):
window = window.getParent()
desktop = window
return desktop
def desktopIsWindowedMode(window):
Determine if a desktop is in windowed mode or not.
Args:
window (ovj) : Window to determine if the parent desktop is in fullscreen or windowed mode
Returns:
isWindowMode (BOOL) : True if desktop is in window mode
#undecorated = fullscreen
return not Nav.getParentDesktop(window).isUndecorated()
def openNewDesktop():
Open a new desktop window
Args:
n/a
Returns:
desktop (JFrame) : newly opened desktop
#base desktop handle
dHandle = 'Desktop '
#get handles
handles = system.gui.getDesktopHandles()
#no desktops open yet
if len(handles) == 0:
nextIndex = 0
#other desktops open
else:
#get list of the desktop indicies from the handle
openDesktopIndicies = [int(handle.replace(dHandle,'')) for handle in handles]
#get max index and increment for next index
nextIndex = max(openDesktopIndicies)+1
#get the current window
window = system.nav.getCurrentWindow()
#open new desktop with current window
desktop = system.gui.openDesktop(handle=dHandle+str(nextIndex),windows = [window, 'Nav'])
desktop.setAlwaysOnTop(False)
return desktop
def desktopSwapDisplayMode(desktop):
Swap the selected "desktop" to windowed/fullscreen mode from fullscreen/windowed mode.
Args:
desktop (JFrame) : JFrame of desktop to be swapped to windowed mode.
Returns:
n/a
window = desktop
if window.isUndecorated():
# Switch to windowed mode.
window.dispose()
window.setUndecorated(False)
window.setExtendedState(JFrame.NORMAL)
window.setVisible(True)
else:
# Switch to full screen mode.
window.dispose()
window.setUndecorated(True)
window.setExtendedState(JFrame.MAXIMIZED_BOTH)
I am using the script above to first open a windowed desktop so it can be moved wherever, and then press the same button again to change it to fullscreen mode, effectively docking it where it was moved to.
I want to change the icon on the button based on the current mode of the desktop.
I thought of that as well, but there is no event handler, so there would be no "self"
Perhaps I'll forgo the toggle option and just have 2 separate buttons. One to change the window's mode and one to create a new window, giving complete and clear control to the user.
Edit: I just ended up doing this:
It's a much cleaner user experience and I don't have to try and get the mode in an expression.
Buttons:
Scripts:
