Expression to get value from dataset
Very simple question. I’m sure the answer is simple too.
Is there an expression function to read a value from a dataset? Something like getValueAt in Python.
Thanks.
You can use square brackets to read values from a dataset in expressions. The following will read the “Id” column of row 0.
{Root Container.myTable.data}[0, "Id"]
And yes, it also baffles me why this is possible in expressions but not in python…
Extra hint: to read the selected row, it’s best to wrap it in a try clause and give a default return value. That way, you don’t get errors when no row is selected. The following expression will give -1 when no row is selected.
try({Root Container.myTable.data}[{Root Container.myTable.selectedRow}, "Id"], -1)
Very good. Thank you!
I mean, it wouldn't be valid syntax in Python? Subscript keys can only be a single object. dataset[(0, "Id")] seems pretty silly to me. If you want more Pythonic access, use a pydataset - dataset[0]["id"]?
It is possible, but not default, for a python object’s __getitem__ and __setitem__ to handle a tuple. So a custom jython wrapper for Dataset could be registered to support such syntax. If such a wrapper implemented the complete sequence interface, the PyDataset type would no longer be necessary.
Yeah, but registering a wrapper for Dataset could instantly break basically every script anyone's ever written...high regression risk for relatively minor syntax gain (IMO).
FWIW, I have considered injecting such a wrapper in my Simulation Aids module, similar to the way I made PyComponentWrapper uniform across the Swing side of the platform. If I did so, all java objects that implement the dataset interface would suddenly have pythonic semantics everywhere in the entire platform.
Only if you are already registering a custom wrapper for datasets. What I have in mind would preserve the automatic java-jython wrapper's functionality for each implementing class. The only exception would be where Dataset implementations also implemented python's sequence interface.
Actually, it's the comma that makes the tuple, not the parentheses. So dataset[0, "Id"] is the same as dataset[(0, "Id")].
But even dataset[0]["Id"] would look nicer to me.
TIL you can do that in subscript expressions. Neat. Something like @pturmel suggested might happen (in the future) but not anytime soon.
Yes, that's what I meant.
Nah. But it is compatible with slice notation.
Tips:
Add a little air into your expressions to make them easier to read and format code on the forum using the </> button.
'Shipped Pallets data : '
+ {value} + ' Pallets, '
+ len({.../Table.props.data}["LOT"]) + ' LOT, '
+ len({.../Table.props.data}["OrderKey"]) + ' Order.'
will be much easier to read and debug and anyone maintaining the code after you will appreciate it. The expression language ignores line breaks and spaces outside of functions, etc.
Is it possible to read a whole row of data? It doesn't seem to like referencing just the row index... {Root Container.myTable.data}[0] :x:
No, the single subscript syntax for dataset access is documented to mean selecting the given column from row zero.
